HEVEA distribution includes .hva packages that are implementations of LATEX packages. Packages described in the “Blue Book” (makeidx, ifthen, graphics —and graphicx!—, color, alltt) are provided. Additionnaly, quite a few extra packages are provided. I provide no full documentation for these packages, users should refer to the first pages of the package documentation, which can usually be found in the book [LATEX-bis], in your local LATEX installation or in a TeX CTAN-archive.
At the moment, most package options are ignored, except for the babel package, where it is essential.
HEVEA amsmath package defines some of the constructs of the
amsmath package. At the moment, supported constructs are
the cases
environment and matrix
environments [LATEX-bis, Section 8.4], the
environments for multi-line displayed
equations (gather
split
,…) [LATEX-bis, Section 8.5] and the
\numberwithin
command [LATEX-bis, Section 8.6.2].
HEVEA provides support for the amssymb symbols using
Unicode. I found Unicode equivalent for most symbols. However, a few symbols
remain undefined (e.g. \varsubsetneqq
The array
package is described in
[LATEX-bis, Section 5.3] and in the local documentation of modern LATEX
installations.
It is a compatible extension of LATEX arrays (see B.10.2).
Basically, it provides new column specifications
and a \newcolumntype
construct for user-defined column
specifications.
Table 1 gives a summary of the new column
specifications and of how HEVEA
implements them.
m{
width}
Equivalent to the p
column specification (the width argument is ignored, entries are typeset in paragraph mode with paragraph breaks being reduced to a single line break), except that the entries are centered vertically.b{
width}
Equivalent to the p
column specification, except that the entries are bottom-aligned vertically.>{
decl}
Can be used before l
,c
,r
,p{
,m{
orb{
. It inserts decl in front of the entries in the corresponding column.<{
decl}
Can be used after l
,c
,r
,p{
,m{
orb{
. It inserts decl after entries in the corresponding column.!{
decl}
Equivalent to @{
decl}
Note that centered, top-aligned or bottom-aligned
in the vertical direction, do not
have exactly the same meaning in LATEX and in HTML. However, the
aspect is the same when all columns agree w.r.t. vertical alignment.
Ordinary column types (c
, l
and r
do not specify vertical alignment, which therefore becomes browser
dependent.
The >{
decl}
and <{
decl}
constructs permit the encoding of TEX \cases
macro as follows:
\def\cases#1{\left\{\begin{array}{l>{$}l<{$}}#1\end{array}\right.}
(This is an excerpt of the latexcommon.hva file.)
New column specifications are defined by the \newcolumntype
construct:
\newcolumntype{
col}[
narg]{
body}
Where col is one letter, the optional narg is a
number (defaults to 0), and body is built up with
valid column specifications and macro-argument references
int).
Examples are:
\newcolumntype{C}{>{\bf}c} \newcolumntype{E}[1]{*{#1}{c}} \begin{tabular}{CE{3}}\hline one & two & three & four \\ five & six & seven & eight \\ \hline \end{tabular}
The column specification
C means that entries will be typeset centered and using bold
font, while the column specifications E{
num}
stands for num centered columns. We get:
one | two | three | four |
five | six | seven | eight |
HEVEA implements column specifications with commands defined in the
\newcommand
style. Thus, they have the same behavior as regards
double definition, which is not performed and induces a warning
message.
Thus, a column specification that is
first defined in a macro.hva specific
file, overrides the document definition.
The tabularx
package [LATEX-bis, Section 5.3.5] provides a new tabular
environment tabularx
and a new column type X
. HEVEA
makes the former equivalent to tabular
and the latter
equivalent to p{
ignored}
. By contrast with the
subtle array formatting that the tabularx package performs,
this may seem a crude implementation. However, rendering is usually
correct, although different.
More generally and from the HTML point of view such sophisticated formatting is browser job in the first place. However, the HTML definition allows suggested widths or heights for table entries and table themselves. From HEVEA point of view, drawing the border line between what can be specified and what can be left to the browser is not obvious at all. At the moment HEVEA choice is not to specify too much (in particular, all length arguments, either to column specifications or to the arrays themselves, are ignored). As a consequence, the final, browser viewed, aspect of arrays will usually be different from their printed aspect.
The calc
package enables using traditional, infix, notation for
arithmetic operations
inside the num argument to the
\setcounter{
name}{
num}
and \addtocounter{
name}{
num}
constructs (see [LATEX-bis, Section A.4])
The calc package provides a similar extension of the syntax
of the len argument to the \setlength
and
\addtolength
constructs.
HEVEA does not implement this extension, since it does not
implement length registers in the first place.
The inputenc
package enables LATEX to process a file
according to various 8 bits encodings, plus UTF-8.
The one used encoding is specified as an option while loading the package
\usepackage[
encoding]{inputenc}
At the moment, HEVEA recognizes ten latin encodings
(from latin1 to latin10),
the koi8-r encoding,
the ascii encoding,
four windows encodings, the applemac encoding, and the
utf8 encoding.
It is important to notice that loading the inputenc
package
alters the HTML document charset.
For instance if the latin9 input encoding is selected by:
\usepackage[latin9]{inputenc}
Then, the document charset is ISO-8859-15
, which is an
enhanced version of ISO-8859-1
with some characters
for Œ, œ and €.
The rationale behind changing the output document charset at the same
time as changing the input encoding is to allow
non-ascii bytes in the input file to be replicated as
themselves in the output file.
However, one can change the document charset (and the output
translator) by using the internal command \@def@charset
For instance, one can specify latin1 encoding, while
producing HTML pages in ascii:
\usepackage[latin1]{inputenc} %HEVEA\@def@charset{US-ASCII}
See section 8.6 for a more thorough description of HTML charset management.
The inputenc package also provides the
command \inputcoding{
encoding}
that
changes the input encoding at any time.
The argument encoding can be any of the options accepted
by \usepackage[
encoding]{inputenc}
The command \inputcoding
of HEVEA
follows the behavior of its LATEX counterpart, it the sense
that it obeys scope rules.
Notice that \inputcoding
does not change the document output
encoding and charset.
HEVEA implements the following packages: latexsym amssymb, textcomp (a.k.a. “Text companion”) and eurosym (a nice € symbol in LATEX).
The comment package provides two commands,
\excludecomment
and \includecomment
, for (re-)defining
new environments that ignore their content or that do nothing. The
comment environment is also defined as an environment of the first
kind.
HEVEA supports several simultaneous indexes, following the scheme of the index package, which is present in modern LATEX distributions. This scheme is backward compatible with the standard indexing scheme of LATEX.
Support is not complete, but the most useful commands are available. More precisely, HEVEA knows the following commands:
\renewindex
commands that takes the same arguments and that can be
used to redefine previously declared indexes.
\newindex{default}{idx}{ind}{Index}
\index
command except that the information
extracted from arg goes to the tag index.
The tag argument defaults to default
, thereby yielding
standard LATEX behavior for the \index
command without an
optional argument.
There also exists a stared-variant \index*
that Additionally
typesets arg.
default
The multind package is supported to some extend, but index is definitely to be preferred.
LATEX version of natbib is present in modern installations.
Implementation is quite complete and compatible
with version 8.0 of the natbib package
(with the keyval style command \setcitestyle
Unimplemented features are the sorting and compression of references. Automatic generation of an index of citatations is handled, but the current implementation probably is quite fragile.
HEVEA provides a slighty incomplete implementation of the
multibib package. The one non-implemented feature is the
simultaneous definition of more than one bibliography.
That is one cannot invoke \newcites
as follows:
\newcites{suf1, suf2}{Title1, Title2}
Instead, one should perform to calls to the \newcites
command:
\newcites{suf1}{Title1}\newcites{suf2}{Title2}
A basic implementation is provided. At the moment, you can
define one bibliography per included file and no toplevel
bibliography.
HEVEA implementation of this package recognizes the option
sectionbib
and provides the command \sectionbib
to change the sectioning command introduced by bibliographies.
HEVEA offers support for the LATEX package babel. When it reads the command
\usepackage[lang-list]{babel}
it loads babel.hva, and sends it the saved lang-list. The file babel.hva then looks at each language (say x) in it, and loads x.hva, which offers support for the language x. As in LATEX, the last language in the list is selected as default. As an example the command
\usepackage[english,french,german]{babel}
would load babel.hva, then the files english.hva,french.hva,german.hva containing the respective definitions, and finally activate the definitions in german.hva and sets the current language to german.
The following babel commands for changing and querying the language work as in LATEX :
\selectlanguage
: to change the language
\iflanguage
: to branch after comparing with current language
The language specific details are described in the corresponding
.hva
file, just as in the .sty
file for LATEX. Users
need to supply this file for their language, or modify/check the files
if thay are already supplied with the distribution. The list of
languages is given below.
american | austrian | brazil | catalan |
check | croatian | danish | dutch |
english | esperanto | finnish | french |
galician | german | italian | magyar |
norsk | nynorsk | polish | portuges |
romanian | russian | slovak | slovene |
spanish | swedish | turkish |
The languages for which .hva files are available with the distribution are english, french, german, austrian and czech. These may need to be modified as not all accents and hyphenation techniques are supported.
They can be written/modified as simple TEX files (see the section B.16.1.1 on writing TEX macros for details). As an example, one may also take a look at the file french.hva, which describes the details for french.
Note how all definitions are inside the definition for
\french@babel
, which is the command that
\selectlanguage{french}
would call. Similar commands need to be
provided (i.e. \x@babel
in \x.hva
for language
x
Some definitions may involve specifying Unicode characters, for doing
so, using the \@print@u
is recommended (cf. Section 8.3).
The definition of Unicode characters can be found at
http://www.unicode.org/charts/.
Most language specific unicode characters can be found in the first
few files.
LATEX source.
This package in fact provides a enhanced \verb
command that
can appear inside other command arguments.
This command is named \url
but it can be used for any verbatim text, including DOS-like path
names.
Hence, one can insert urls in one’s document without worrying about
LATEX active characters:
This is a complicated url: \url{http://foo.com/~user#label%coucou}.
which gets typeset as: “This is a complicated url: http://foo.com/~user#label%coucou.”
The main use for the \url
command is to specify urls as arguments to
HEVEA commands for hyperlinks (see section 8.1.1):
\hevea{} home page is \ahrefurl{\url{http://hevea.inria.fr/}}
It yields: “HEVEA home page is http://hevea.inria.fr/”.
However the \url
command is fragile, as a consequence it
cannot be used inside \footahref
first argument (This is a
LATEX problem, not an HEVEA one).
The url package solves this problem by providing the
\urldef
command
for defining commands whose body is typeset by using \url
\urldef{\heveahome}{\url}{http://hevea.inria.fr/}
Such a source defines the robust command \heveahome
as the
intended url.
Hence the following source works as expected:
Have a look at \footahref{\heveahome}{\hevea{} home page}
It yields: “Have a look at HEVEA home page”.
Using \url
inside command definitions with a
i argument is a bad idea, since
it gives “verbatim” a rather random meaning.
Unfortunately, in some situations (e.g, no %
, no #
it may work in LATEX. By
contrast, it does not work in HEVEA. In such situations,
\urldef
should be used.
HEVEA implementation is somehow compatible at the “programming level”.
Thus, users can define new commands whose argument is understood
verbatim. The urlhref.hva style file
from the distribution
takes advantage of this to define the \url
command, so that it both
typesets an url and inserts a link to it.
\input{urlhref.hva} Have a look at \url{http://hevea.inria.fr/}
It yields “Have a look at http://hevea.inria.fr/”.
The urlhref.hva
style file (which is an HEVEA style file and not a LATEX
style file) can be adequate for bibliographic references,
which often use \url
for its typesetting power.
Of course, loading urlhref.hva only makes sense when
all arguments to \url
are urls…
These two packages provide new commands and environments for processing verbatim text. I recommend using moreverb rather than verbatim, since HEVEA implementation is more advanced for the former package.
I strongly recommend the listings package. Learning the user interface requires a little effort, but it is worth it.
HEVEA features a quite compatible implementation, please refer to the original package documentation. Do not hesitate to report discrepancies. Note that HEVEA does not produce very compact HTML in case you use this package. This can be cured by giving hevea the command-line option -O (see C.1.1.4).
The lstlisting environment is styled through
an homonymous style class (see 9.2 and 9.3) and
most lstlisting environments get translated to DIV
elements with the approriate \getenvclass{lstlisting}
class,
which, by default is lstlisting.
A few points deserve mention:
font-family:monospace;
and white-space:pre;
, which, more or less,
specify non-proportional font and mandatory line breaks.
In case you replace lstlisting by another style class (by
\setenvclass{lstlisting}{
another one}
), your
alternate definition should probably feature an identical
specification. Otherwise, rendering would be poor, as regards spacing
and line breaks.
Here is how specific listings are styled.
We first define a new environment to typeset programs written in the C
language, by using the command \lstnewenvironment
\lstdefinestyle{colors}{keywordstyle={\bf\color{blue}}, commentstyle={\em\color{magenta}}} \lstnewenvironment{clisting} {\setenvclass{lstlisting}{clisting}\lstset{language=C, style=colors}} {}The command
\lstnewenvironment{
name}{
starting
code}{
ending code}
is from the
listings package, with similar semantics.
In the starting code above, the fragment
instructs HEVEA to
use the style class clisting locally (notice that it could just
be another name). The style class clisting is defined in
the document preamble as follows:
\newstyle{.clisting}{font-family:monospace;white-space:pre; border-left:solid black;padding-left:2ex;margin-left:2ex;}Typesetting a C listing with a black border on the left is then as simple as:
\begin{clisting} /* Compute, guess what! */ int fact(int n) { int r = 1 ; for ( ; n > 0 ; n--) { r *= n ; } return r ; } \end{clisting}The final result is: directive]#
DIV
elements.
Instead they get translated to one cell tables whose TD
and TABLE
elements
are styled through style classes lstlisting and
lstframe, respectively. Of course, those two style classes
follow the usual \setenvclass
/\getenvclass
mechanism.
That way, one can for instance center all framed listings by issuing
the following declaration in the document preamble:
\newstyle{.lstframe}{margin:auto;}Notice that the default style class lstframe is empty.
white-space:pre;
style declaration is still a
bit young, and some browsers implement it in rather uncomplete
fashion. This is particularily true as regards text copy-pasted from
browser display. In case you want to provide your readers with easy
copy-paste of listings, you can, by issuing the command
\lstavoidwhitepre
in the document preamble. Then,
white-space:pre;
is not used any longer: spaces get rendered
by non-breaking space entities and linebreaks by <BR>
elements,
which significantly increase output size. However, as a positive
consequence, display remains correct and text copy-pasted from browser
display indeed possesses the linebreaks shown in display.
LATEX source for the longtable and supertabular packages.
Those two packages provide LATEX users with the possibility to typeset tabular material over several pages [LATEX-bis, Section 5.4]. Of course, HEVEA does not care much about physical pages. Thus the supertabular and longtable environments are rendered more or less as tabular environments inside table environments.
The mathpartir package, authored by D. Rémy, essentially provides two features:
\inferrule
(and its starred variant) for
typsetting inferences rules.
We give a short description, focussing on HEVEA-related details. Users are encouraged to refer to the original documentation of the package.
In the following, comments on rule typesetting apply to HEVEA output and not to LATEX output.
In its LATEX version, the mathpar environment is a “paragraph mode for formulas”. It allows to typeset long list of formulas putting as many as possible on the same line:
\begin{mathpar}
A-Formula \and
Longer-Formula \and
And \and The-Last-One
\end{mathpar} |
In the example above, formulas are separated with \and
. The
LATEX implementation also changes the meaning of paragraph breaks
(either explicit as a \par
command or implicit as a blank line)
to act as \and
. It also redefines the command \\
as
an explicit line-break in the flow of formulas.
\begin{mathpar}
\int_0^2 xdx = \frac{3}{2}
\int_0^3 xdx = \frac{5}{2}
\end{mathpar} |
The HEVEA version is simplistic:
Formulas are typeset in math display
mode,
\and
separators always produce horizontal space, while
always produce line-breaks.
However, when prefixed by \hva
the meaning of explicit
separators is inversed: that is,
\hva\and
produces a line-break, while \hva\\
produces horizontal space.
Hence, we can typeset the previous example on two lines:
\begin{mathpar}
A-Formula \and
Longer-Formula \hva\and
\end{mathpar} |
It is to be noticed that the LATEX version of the package defines
\hva
as a no-op, so as to allow explicit instructions given to
HEVEA not to impact on the automatic typesetting performed by LATEX.
The \inferrule
macro is designed to typeset inference rules. It
should only be used in math mode (or display math mode). It takes
three arguments, the first being optional, specifying the label,
premises, and conclusions respectively. The premises and the
conclusions are both lists of formulas, and are separated by
A simple example of its use is
\inferrule [label] {one \\ two \\ three \\ or \\ more \\ premises} {and \\ any \\ number \\ of \\ conclusions \\ as \\ well}
which gives the following rendering:
Again, HEVEA is simplistic. Where LATEX performs
actual typesetting, interpreting \\
as horizontal or
vertical breaks, HEVEA always interpret \\
as an
horizontal break. In fact HEVEA interpret all separators
, \and
) as horizontal breaks, when
they appear in the arguments of the \inferrule
command.
Nethertheless prefixing separators with \hva
yields vertical
breaks:
\inferrule
{aa \hva\\ bb}
{dd \\ ee \\ ff} |
The color of the horizontal rule that separates the premises and
conclusions can be changed by redefining the command
\mpr@hhline@color
. This color must be specified as a low-level
color (cf. Section B.14.2.2).
By default, lines are centerred in inference rules. However, this can be changed either by using \mprset{flushleft}
or \mprset{center}
, as shown below.
$$\mprset{flushleft}
\inferrule
{a \\ bbb \hva\\ ccc \\ dddd}
{e \\ ff \hva\\ gg}
The mathpartir package provides a starred variant
\inferrule*
. In LATEX, the boxes
produced by \inferrule
and \inferrule*
differ as regards
their baseline, the second being well adapted to derivation trees.
All this is irrelevant to HEVEA,
but \inferrule*
remains of interest because of its interface:
the optional argument to the \inferrule*
command is a list of
key=value pairs in the style of
keyval.
This makes the variant command much more flexible.
Additionally, the value-less key center
centers premises and
conclusions (this is
the default), while flushleft
commands left aligment of
premises and conclusions (as \mprset{flushleft}
does).
Other keys defined by the LATEX package exist and are parsed, but
they perform no operation.
As an example, the code
produces the following output:
This package should be present in modern latex installations. Basically, the package defines a boolean register pdf, whose value is true for tools that produce PDF (such as pdflatex) and false for tools that produce DVI (such as latex).
The hevea version of the package simply defines the boolean
register pdf with initial value true. Command-line option
-pdf is also added to imagen command-line
options (by using the command \@addimagenopt
, see
Section 10.7). As a result, imagen will
normally call pdflatex in place of latex.
In case standard latex processing in imagen is
wished, one can issue the command \pdffalse
after loading the
ifpdf package and before \begin{document}
. Then, no
command line option is added.
Hence, to achieve latex processing of the image
file, while still loading the ifpdf package, one writes:
\usepackage{ifpdf} %HEVEA\pdffalse
HEVEA features an implementation of Andrew Seagar’s technique for Thai in LATEX, by the means of the package thai.hva in the distribution.
As regards input encoding, Thai users of HEVEA could (perhaps) use
\usepackage[utf8]{inputenc}
However, the typesetting of Thai is more subtle than just proper
characters. For that reason, Thai in LATEX is better performed by
another technique, which HEVEA supports. See this specific
document.
The hanging package is implemented. HEVEA implementation consists of no-ops, except for the hangparas environment, which is partially implemented. Assume the following usage of hangparas:
\begin{hangparas}{
wd}{
n}
…\end{hangparas}
where wd is a length that makes sense both for LATEX and CSS (typically 2ex). Then HTML output will reproduce LATEX output for n=1, regardless of the given value of argument n. That is, in any paragraph inside the environment, all lines except the first get indented by wd.
The fancyverb and colortbl packages are partly implemented.
The xspace package is implemented, in simple cases, rendering is satisfactory, but beware: HEVEA differs significantly from TEX, and discrepancies are likely.
The chngcntr package is implemented. This package provides commands to connect (and disconnect) counters once they are created(see http://www.tex.ac.uk/cgi-bin/texfaq2html?label=addtoreset).
The import package is partially implemented: all starred commands are missing.
The booktabs package is implemented. This package provides nicer rulers in tables as specific commands. HEVEA defines those as no-ops.
